A much higher rate of duplicate work units? I'm seeing I would say a near constant 2 of the 25 gpus processing identical wus but never the same two have the dupes. Did F@H make a change in how many copies of the same wu are distributed?
That wouldn't explain one person with fast GPUs getting multiple units with the same PRCG though, since they wouldn't be missing any deadlines.[OCAU]EvilGenius;1034436890 said:I would expect it's from people folding on cards too slow to meet the preferred deadline. Once the preferred deadline is reached a duplicate workunit is released to someone else just in case the original doesn't meet the final deadline.
Well, my line of reasoning is that one person wouldn't be assigned two copies of the same WU for that reason, since at worst, if it isn't returned by the deadline, it would be send out to one person. So that wouldn't explain why someone would get two copies.[OCAU]EvilGenius;1034440919 said:I guess that depends on how smart the assignment server is. If a work unit is duplicated and then reassigned to a faster contributor (due to the slow contributor missing the preferred deadline), but both the slow and fast contributors return the work unit before the final deadline, you could end up with 2 work unit 'lines' with the same run/clone/gen. Unless of course the assignment server is smart enough to recognise that and kill off one line. But I'm not sure about that, can't find any info that detailed.
You will receive credit for every workunit you submit.Just wondering if I'm getting points for both GPUs, and not just one.
