May 16, 2007 #1 S sceevey n00b Joined Nov 5, 2005 Messages 63 Hello, just yesterday I began to get random mouse disconnects. I hear the disconnect sound and such, but it's annoying when I'm scrimming. Mouse is a Logitech G5 @ 500hz about a year old. Thanks for the help!
May 16, 2007 #2 M MattyC Gawd Joined Mar 13, 2007 Messages 797 Have you tried plugging it in to a different USB port?
May 16, 2007 #4 M MattyC Gawd Joined Mar 13, 2007 Messages 797 I dunno if this will help, but it is worth a try. Go into device manager and uninstall the mouse and the USB root hub and then let them reinstall.
May 17, 2007 #5 S sceevey n00b Joined Nov 5, 2005 Messages 63 MattyC, I'll try that if it goes crazy again. It hasn't done it once this morning, hopefully it stays that way *crosses fingers*
May 17, 2007 #6 S SpeedRunner Guest I have the same mouse and don't have that problem. Do you use a wood surface or a mouse pad?
May 18, 2007 #8 S sceevey n00b Joined Nov 5, 2005 Messages 63 Ok, so I bit the bullet and decided to get a new mouse. I got the Razer Deathadder. One problem, the firmware is version .01 and it won't update :X. here is a pic : http://img518.imageshack.us/img518/391/untitledjm2.jpg EDIT: Actually, it doesn't seem like any changes I make in the Razer control panel works either.
May 18, 2007 #9 M Mansize_tissue 2[H]4U Joined Jan 1, 2007 Messages 2,501 Aren't you very happy with the Deathadder, then? How's the shape of it compared with the G5?
May 18, 2007 #10 S sceevey n00b Joined Nov 5, 2005 Messages 63 I got it fixed, some razer settings weren't enabled. (stupid me) The deathadder is actually very comfortable. I like the shape of it a lot more than the G5.
