Harley Davidson 1/2 Scale Mini ITX
00buck
The finished project.
I made the motherboard tray from a emachine side panel and back plate.
Modded the pico psu with a 4 pin mb connection and the Intel D945GCLF / 2gig Kingston
Motherboard Mounted
To keep the Testors Kit Functional I had to build a frame for a little more room
Frame and Motherboard assembled
You can see the drive for the motor and the sound board under the base.
Quick test to make sure it works.
The back.
I themed it with Stardock MyColors Harley Theme for the XP OS
http://www.stardock.com/products/mycolors/gallery.asp?p=harleydavidsonclassic&c=rides
