Hi,
I want to buy a Server to be able to use XenServer with (~20-40) of VM-s running at the same time like XenApp, XenDesktop, Windows 7, Windows Server 2008, etc. We would need a recommendation for the hardware specs for this server. Also it would be great to know the size of the server.
This is the most important for me, we are not sure what is the number of NICs needed (we are not sure what is the speed impact of having multiple VM-s using the same NIC).
15 users will use this Server sometimes at the same time.
The Server should be DELL. I would like to have only 1 Physical Server but maybe it is better to have 2 or 3 smaller.
Thanks a lot.
Thanks a lot.
