Hardware sanity check
Roscowgo
If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
1080p single monitor gaming, lan party travel
~1100, no
US. Beckley Wv
Cpu, ram, case, ssd, psu, cooler, video card,
Wd 7200 1tb hdd possibly.
6) Will you be overclocking?
Yes
1080p, projector
Sanity/hardware check. Not sure.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Small, handle mild -medium overclocking
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Yes, win 7x64
Asrock z79m-itx http://www.newegg.com/Product/Product.aspx?Item=N82E16813157531
4670k http://www.newegg.com/Product/Product.aspx?Item=N82E16819116899
Msi r9 280 gaming http://www.newegg.com/Product/Product.aspx?Item=N82E16814127789
Obsidian 250d http://www.newegg.com/Product/Product.aspx?Item=N82E16811139033
H100i http://www.newegg.com/Product/Product.aspx?Item=N82E16835181032
Sandisk ssd http://www.newegg.com/Product/Product.aspx?Item=N82E16820171740
Corsair 16 gig kit http://www.newegg.com/Product/Product.aspx?Item=N82E16820233538
G-550 psu http://www.newegg.com/Product/Product.aspx?Item=N82E16817151119
16 gigs of ram is for ramdisk usage. Small minecraft servers etc. i'll probably shoehorn a 1tb mechanical in there for storage and maybe up to 3 tb later on.
Save some money on the video card:
$233 - Gigabyte GV-R928WF3OC-3GD R9 280
Double the SSD capacity now. You'll gain better performance on top of the additional storage.
$110 - Crucial M500 240GB SSD
Grab the Intel Core i5-4690K while it's on sale:
$230 - Intel Core i5-4690K (included $10 discount promo code EMCPBPE23, ends 8/11)
Don't forget to take advantage of the promo code on the Corsair H100i.
If you have a microcenter around you can get the 4670k for $200 and 40 off that asrock board with another $10 mir, but you have to pay tax
No Mcs anywhere near unfortunately, I think even the nearest best buy is about 3 hours away.
Ah nope, they must have stuck one in about an hour away while I wasn't looking.
As for MC.... nearest is 131 miles. :eek:
