Scenerio:
Wife is pregnate
Need to work from home which requires broadband & VPN to the office.
Cable Broadband is the only option.
Only available cable jack location requires wireless hardware.
Will be networking a desktop (XP Home) and a laptop (XP Pro)
Laptop will be used at work (wired) and home (wireless).
Question:
Due to the above scenerio, I need to set up a wireless network at my house that incorporates a cable broadband connection, a desktop and a laptop that will be used at work and at home that will be able to use a VPN that connects to work. I do not have any of the hardware to accomplish this task, which looks like it will require a cable modem, router/access point and nic cards.
Based on this information, what wireless standard and brand of hardware would you recommend? I am leaning toward the Linksys brand, as they have all the components I need and will essentially be a "matched" set. Also, periodically I will be printing and transfering 10mb+ Word docs back and forth.
Your recommendations would be greatly appreciated.
Thanks
Wife is pregnate
Question:
Thanks
