Hardware RAID 5 options for Win 7?
Phixzet
Hey guys.
I have an Areca 1220 card, and I love it.
But I want to migrate to Win 7, fresh install.
Areca doesn't seem to support Win7 from what I can tell.
When I build a new system, with new HD's, I still want to go with a Raid 5 storage system, using large HD's.
Since I'm buying all new (or plan to at least)... I'm open to suggestions for what HW I should get.
Any advice for me?
TY :)
hmm, does Areca have vista drivers? it should work if it does.... you could always try it...
are you looking for OS drive or separate array?
Thanks.
It would be my main (OS) drive.
I wish there were MB's out there that had RAID5 on the motherboard. While I love my Areca, it's getting old - always worry about it failing. (Although well past the infant failure period)
I would like to have one less card obstructing airflow though... Esp on my new build I'll be adding another card that I don't currently have in my system. (X-Fi)
