Monkeypillow
- Aug 30, 2006
What all do I need to mount one of these to my case?
You need:
Holes. Large ones. Small ones.
screws - you can use machine screws and nuts, or hex head cap screws and nuts.
The smaller holes are just right for #6 machine screws/cap screws, and the larger ones are just right for #8.
I purchased stainless steel socket head cap screws and stainless steel nuts to match them for the mounting. (8/32)
I got my stuff ultra cheap from www.boltdepot.com
Meaningfully? It depends on the results you are after. Yes it’s an extra effort. Countersinking the hole on thin material will oversize the hole, but so what. It’s not the space shuttle. Look at the radgrills gallery and you can see where countersunk screws were installed without countersinking the holes. Looks bad. Look at all the ones with protruding screws. Nat as bad, but not a smooth professional clean look either. Countersinking aluminum is no harder then wood. Just go very lightly to remove the right amount of material from the top edge and you are golden. Countersinking bits are not that hard to find, and I’ve even simply used a larger drill bit before. It doesn’t have to be air-worthy. Just be gentle and work your way up to the right size/depth.
While harder to pull off, dimpling doesn’t have to be hard either if you have the right something underneath the material for the female die. I’ve used a countersunk screw itself for the male. Hammer-punch-screw on top, support on the bottom. Again, the problem with a dimple is the need for the material underneath to be countersunk or dimpled.
Take your grill to a local hardware store and find screws of proper length that fit the holes.
When they are this size they are typically referred to as screws. You can call them small bolts if you wish. You will need nuts for the screws. Washers are always a good thing to put under the nut. Lockwashers between the flat washer and nut even better.
Sounds good..screw --> radgrill --> case --> flat washer --> lockwasher --> nut?
Sounds good..
They also make locknuts which would makeup the lockwasher and nut. Look at the boltdepot link above or the guy in the hardware isle will show you.
Not sure why you would need a nylon washer, but if you use a nylon washer dont use a lockwasher. They are meant more for a metal to metal interface.
What size holes do I need to drill for the Radgrill?
