So here is what I started with just in case it matters:
i5-750
Gigabyte P55-UD3R
Radeon 4890
4GB G.Skill DDR3
550w Corsair PSU
Crappy low profile heatsink
Seagate 500gb HD
My computer has gone through a variety of issues over the last month so I am hoping maybe someone will have an idea that I haven't.
A few ago I upgraded my heatsink to an H60 and added a Kingston SSD to my setup that was working normally. For about a week the additions worked normally, and then upon installing Acrobat Reader and attempting to open a PDF my computer began to get random blue screens.
I thought I had possibly had an issue installing my OS so I decided to try and reformat the SSD. However, my computer began to hard lock about halfway through the Windows installation.
Having had similar issues in the past I thought that I might have a bad stick of ram. I pulled one of my sticks and Windows installed normally.
The computer worked normally for about a week and I thought I had solved the problem but then after playing Starcraft II for about 2 hours, without any temperature issues, the computer just shut itself down. No blue screen, no errors anything, just turned off.
I tried to start running diagnostics and got through a couple before the computer would even hard lock while in Ultimate Boot CD. Both Sticks of RAM passed MEMTEST and I cleared the CMOS before the computer began to turn off roughly two seconds after turning it on.
I now thought it seemed like a PSU. I swapped in a working PSU and received the same results.
I then began to think that I might have a short or something so I took the MOBO and all out of the case and started to try and boot with just a CPU, RAM, and a video card. After figuring out that the 800d and my MOBO doesn't have a speaker, I got a speaker plugged in and got the post code of 1 long, 1 short. According to the Interwebs, that meant there was a problem with the MOBO, so I ordered a new MOBO.
Upon receiving the new MOBO(MSI P55-CD53) I plugged in the essentials and did not get any kind post code. Rather confused I plugged in the video card and got no feed from the video card to the monitor.
I have swapped between 2 previously working video cards, while also trying 2 different previously working PSUs.
So now my computer seems to turn on normally and then sends no feed to the video card. Having gone through all this other stuff I am kind of at a loss. My last guess is a CPU, which might prompt a complete upgrade, or I will just RMA it to Intel and hope for the best.
Any ideas or help would be greatly appreciated.
i5-750
Gigabyte P55-UD3R
Radeon 4890
4GB G.Skill DDR3
550w Corsair PSU
Seagate 500gb HD
