Hi there,
I have a boot problem while booting my pc.
If I try to boot windows (or windows recovery) the system is boot looping, A second or two after the logo moving reboot. Sometimes if finally work and then the system boots and works well.
If I try to boot ubuntu, it is most of the time freezing but if I boot in recovery I have way more information.
When not working I have some messages like that:
When it boots it is like that:
And when it boots everything is working fine.
I tested my ram, tried only one at a time. Same behavior, with less memory...
I tried to remove optical drive and hdds, same behavior less hdds.
I had a clean and an outside look at my Seasonic X-560. The main caps are looking ok, I just spotted a filter inside who took an odd shape along the years. During basic desktop internet workload my system only draws 80W at the plug but I suspect that power is failing while ramping up all the cpu core. I emailed seasonic but no answer so far. That is also one of the few parts still on warranty.
CPU I7 2600K not overclocked, running not very hot, it is supposed to be reliable but it is hard to be sure without another on hand.
Mobo Asus Z68Pro latest bios (3603), I tried a factory reset and all. I did not spot issue with capacitors either but it might be a mobo problem too. A deficient phase power, a conflict with the many hdd and usb plugged?
The hdd arte fine to me the 840pro is aligned, it is a bit mess but it used to boot very well:
http://paste.ubuntu.com/7902752/
Any idea how to troubleshoot this problems without buying PSU, Mobo and CPU? Thanks
Code:
7[ second] boot: CPU3: Not responding
13[ second] boot: CPU4: Not responding
Code:
#3 #4 #5 #6 #7...
