Hardware help for a Esxi box
Gimbli
Hi
im am trying to find parts for a EsXi 5 system and are a bit confused over some hardware .
im looking for a cheap box and after have read some forum phosts and articles i have been looking on :
Cpu : AMD FX-6100 and 8150
Motherboard : ASRock 970 Extreme4 / ASRock 990FX Extreme4
Memory : Corsair 16GB (2x8192MB) CL11 1600Mhz XMS3
i havent found enny info if 8150 works with Esxi 5
i do know that ASRock 970 have IOMMU but dont know if the onboard systems work in esxi
-Gimbli
English is not my primary language
I have the Asrock 970 Ext 3 and it works with ESXI 5.
The 8150 should work as long as the MB supports IOMMU.
