I'm looking for a hardware firewall solution that allows me to access the server remotely, allow VPN access (via Windows Server SMB VPN), allows Outlook Web Access, all while allowing me to selectively block specific IP addresses or ranges from ever reaching my server. All while being fairly user friendly.
Got any brands or models you recommend and work with that will allow this?
There have been multiple attemps to get into my windows server from somethin other than traditional methods that makes me think security hole. The thing is that the server is up to date on all patches and only has the ports open for the aforementioned programs. Nevertheless it has disrupted the server enough to cause me a headache so I'd rather just ban that damn IP range that keeps trying as it's been similar addresses from europe that's been doing the same attack over and over for the last week.
