I'm looking to replace the old school PERC 5i storage array and onboard RAID1 for OS in my file server with newer gear.
New system hardware is running on a SUPERMICRO MBD-X9SCM-F-O.
End goal is to use two controllers with the following setup. PCI-E.
Controller #1 (smaller, only needs to support RAID0/1, single internal 8087 would be ideal)
2xRE4's in RAID1 for system OS
2xCheetah 15k SAS in RAID1 for scratch/VMs
Controller #2 (beefier, RAID6 + array expansion required, hot spare support, etc, minimum of 2 internal 8087's)
8xWD red's in RAID6 to start, expansion to 16 drives ideal (4x internal 8087's as backplane is one per 4 drives and I don't want an expander if possible)
I would prefer them to be the same manufacturer. Controller #1 will need to be bootable. WebGUI would be interesting, even more so if both controllers can use a single pane of glass.
Thoughts?
Budget is 'lets be reasonable here'.
Under $700 total.
Thoughts?
