draconius said:I can't make any recommendations for some brand firewall (linksys, dlink, pix, watchgaurd, etc) but I would like to recommend some of the things below, if you have a spare box sitting around and want to try out something different.
If you are looking for different full on firewall-distro ideas try:
Misc. Firewall Distributions-
http://www.astaro.com/
http://www.freeswan.org
http://www.strongsec.com/freeswan/
http://www.clarkconnect.org
http://www.smoothwall.org
http://m0n0.ch/wall/
http://www.coyotelinux.com/
http://www.freesco.org/
http://www.zelow.no/floppyfw/
http://edge.fireplug.net/
http://www.gnatbox.com
http://www.dubbele.com/index.html
FreeBSD stuff-
http://www.unixforums.net/modules.php?name=Sections&op=viewarticle&artid=40 - IPF/IPNAT
http://www.unixforums.net/modules.php?name=Sections&op=viewarticle&artid=41 - IPFW/NATD
http://www.unixforums.net/modules.php?name=Sections&op=viewarticle&artid=66 - Redundant firewall/vpn solution
http://www.unixforums.net/modules.php?name=Sections&op=viewarticle&artid=47 - Advanced IPFW with WF2Q
http://www.unixforums.net/modules.php?name=Sections&op=viewarticle&artid=26 - IPfilter setup script
http://www.unixforums.net/modules.php?name=Sections&op=viewarticle&artid=4 - Setting up IPFW (basic)
http://www.schlacter.net/public/FreeBSD-STABLE_and_IPFILTER.html - Freebsd stable firewall with IPFW
OpenBSD Stuff-
http://www.unixforums.net/modules.php?name=Sections&op=viewarticle&artid=38 - Firewalling/setting up gateway
Linux Stuff-
http://www.unixforums.net/modules.php?name=Sections&op=viewarticle&artid=36 - Setting up firewall
http://ezunix.org/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=24&page=1 - Another firewall guide
mpeg4v3 said:I highly recommend m0n0wall (http://m0n0.ch/wall), all it needs is a spare PC to run on. I currently have the cd&floppy based version running on a PC without a hard drive that acts as a firewall between my university network and my network- while still passing on dhcp so that I can still use school IP addresses.
draconius said:I can mail you a pentium 100 that will work fine
I have run firewalls on T1's with a 486 for doing basic traffic filtering, all the way up to more of a dual 350 for a box thats doing vpn/ipsec stuff, along with traffic queuing (QoS) and alot of advanced filtering. so basically, I would look for something like a PII 233 with 128Mb of ram and a couple GB hdd, that should suit you well. If you are at school, you migh tlook for a box that runs really quiet so that you can leave it on all the time and not worry about it...and not get annoyed by the noise heh
