Harddrive Cloning (?)
liquidfluidity
Not sure if that is the proper terminology but here's what I want to do. I am wanting to upgrade my RaptorX to a newer Velociraptor. What is the best way to copy the RX to the VR? This is my OS drive including installed apps , etc. I just don't want to have to reformat if I don't have to. It took me a long time to get it set up to my liking and I would hate to lose all of my settings. I have heard that Acronis or Norton Ghost will do the trick. Is this correct? What about the drive letter - will it be different? Totally a noob at this!:rolleyes:
You can try DriveXML since its free.
I've had success with it in the past. Not feature filled, but simple enough.
You will keep your drive letter.
http://www.youtube.com/watch?v=PTEnKA7tOXM
Also after you restore the image to the new drive, set the partition as active.
I used a gimped version of Acronis that came with my Seagate drive. I have also used EASEUS Todo backup and it is free.
Once I cloned mine, I shut down, removed the old drive, booted up and there was no difference.
