Harddrive Cache
YoMoma
How does harddrive cache affect a hard drives perfomance?
Would buying one with 16mb cache be that much better than one with an 8mb cache?
Depends. Larger buffer always helps application level performance (loading Windows, programs, games, etc). However, it won't increase the transfer rate of the drive (moving MP3s/movies back and forth, etc).
Clicky shows the advantages of moving to a 16MB buffer (admittedly a modest increase in density/transfer rates is also a factor here) on flaghsip Hitachi drives. In the buffer sensitive Office DriveMark, the 16MB buffer boosts performance over 25%. The High-End (workstation) DriveMark is a little more sensitive to linear transfer performance and doesn't emphasize buffer strategy as much as the Office Test. Still, going to 16MB boosts throughput 23%. Gains in the gaming tests, which are very sensitive to seek performance (which the 500GB/16MB drive is actually a little slower in seek time than the 400GB/8MB drive) are smaller, tightly clustered in the 13-14% range in FarCry, Sims2, and WoW.
All other things being equal, expect the 16MB drive to be at least 15% faster in application level performance, as much as 30% faster depending on the application. Of course, gains in application level performance are hard to quantify, but going to a 16MB drive will increase the responsiveness of your system - even better when you consider it's basically free on many drives.
