Ok, so I just bought the Nikon D800 (it takes 36 megapixel images for those unfamiliar). Furthermore for those those that aren't familiar, this camera takes an average lossless compressed RAW file at about 40mb per image. When editing and using this file it becomes pretty damn huge.
Anyways, I currently have a i7 920 system on windows 7 pro 64bit oc'ed at 3.2ish ghz with 12 gb triple channel ram. Also I have two radeon 6950's running together in crossfire (I am also a big gamer). Furthermore, I am running three IPS 24" panels at 1920x1200 each and an occasional 47" 1080p TV in addition.
Anyways, I would like to see a significant improvement upgrading to any newer mobo/processor/ram combo. I am not looking for small improvements, I can wait another year or two if I wont see a big change. (my PC destroys any game I throw at it these days). What I would really love to see is faster processing of my RAW photo files.
Anyways, to answer those common questions the FAQ advised.........
1) What will you be doing with this PC? Gaming & Nikon Capture 2 (as well as other less intensive stuff)
2) What's your budget? Would love to spend under 2 grand on the upgrade. Remember, I have two newish 6950's (running in crossfire) so I won't have to buy those. Also, I have 12 gb of corsair dominator triple channel ram (2gb per slot currently). Also my power supply should still be good to go (read below for details)
3) Which country do you live in? St. Louis, MO
4) What exact parts do you need for that budget? I want a new case (FULL TOWER ONLY) (with usb 3.0 on front port), mobo, processor, memory if I need it
5) If reusing any parts, what parts will you be reusing? Have a KINGWIN Mach 1 ABT-1220 power supply. Will reuse my two MSI 6950's for sure. Will reuse RAM if I can. Have lots of HD space, though I am ok upgrading to more space. NOTE: currently I am running RAID 1 with a 3rd HD running backup on the raid 1 array (this runs as a manual (every 3 months or so) back up). All my HD's are currently 1tb WD Caviar Blacks.
Furthermore I won a free Antec h20 920 in their gaming contest (because I own at battlefield). Would love to reuse it.
6) Will you be overclocking? If I need to, otherwise I'd rather keep my heat down.
7) What is the max resolution of your monitor? What size is it? 1920 x 1200. 24" This won't change. These are expensive IPS panels.
8) When do you plan on building/buying the PC? Next 3-6 months I think?
9) What features do you need in a motherboard? Raid, Crossfire, USB 3.0, Sata whatever is good these days. I already have an ASUS Xonar 7.1 sound card, though I also have the Corsair 1500 (which bypasses it, le' sigh)
10) Do you already have a legit and reusable/transferable OS key/license? Windows 7 pro 64bit
