Ubermouser
- Dec 13, 2003
Well, my rig, for reference:
Intel Pentium 4 3.0E socket 478 (2 days old)
2x 512mb Mushkin Black level 2 ddr3500 dimms (1 year old)
Abit Ic7 Max3 I875 motherboard (10 months old) /w Bios 13, revision 1.0
Asus 9800xt 256mb Radeon graphics card (1 year old)
Turtle Beach Voyetra 7.1 surround sound card (1 year old)
2x Western Digital 10000rpm Sata 36gb Hard Drive "raptor" (10 months old)
Antec 550 watt Truecontroll power supply (7 months old)
Lite on 24x/40x/24x cdrw/dvd drive (1 year old)
Mitsumi 7-in-1 Media drive (floppy/memory) (1 year old)
I chose to watercool my computer, but dropped the CPU (2.6C) during the Xfer. I bent back the ruined pins and tried anyways, attaching everything into the motherboard. The system boots, but gives CPU unworkable. I skip the bios, (I didnt change settings), and boot to windows. During the 10 seconds before the "Welcome" screen and after the "windows is loading" screens show up, the computer crashes. It ceases to boot again. I remove the cpu in order to replace it but find the now dried up remains of the radiator fluid underneath the processor. I dry the board with a multitude of cotton ear-schwabs, giving the motherboard its "pristine beauty" again.
I then insert an Intel Pentium 4 3.0E into the setup, and to my suprise, the computer works flawlessly. The computer easily flys through its 25-hr test, though I didnt extensively try any Prime95 or Memtest86.
I wakeup to very low temperatures, nearly 10C lower than the night before. Time for some overclocking.. but first I had to do homework.
In the process of reading a document, the computer crashes - no blue screen, simply frozen. No response from any perhiperals. I restart, thinking the whole thing was a fluke.
THE COMPUTER DOESNT BOOT! Same error as before: no bios beep, no display, nothing going on upstairs - though both motherboard power lights are on, including the case light. The hard-drive light indicates the hard drives seem to be spinning up. Yet there is no bios beep. (no leaks)
I havent done anything up to this point, but could anyone here supply me with technical support? Its so upsetting to have a product work for nearly a year, then succumb to an unknown fate..
