hard lockups
lodingi
i have been experiencing these little micro-stutters and occasional hard lock ups when gaming. the game will freeze for about 10 seconds. i don't know if it's a software problem or a hardware problem. what's the proper troubleshooting steps to take? i have already tried different drivers for my 7600gt. thanks for your help.
i don't o/c the card but the card came factory o/c'd from evga. it's running at 580/750.
I have that same card and its kinda of picky. I had to under clock it to run without any problems. What version of the drivers are you running?
right now i am using xg-91.47 drivers.
lodingi said:
i just clocked down to 560. i hope this solves my problem. thanks.
Try running some benchmarks and play some games, post back if you still have problems. If everything is good you can clock it back up a little at a time.
Is your CPU overclocked?
Maybe new chipset drivers for your motherboard..
lodingi said:
*sigh* it's still happening. i don't what to do now. um. help. lol.
Sounds like you may need to RMA the card. Whats the temp at?
Can you run something like 3Dmark06 all the way through?
thanks for the responses.
i am using the current n4 chipset.
my temps are 49c idle 55c under load
my cpu is not o/c'd.
i can run 3dmark 06 all the way through.
i was playing fear today and when running around the map i would literally step step pause. step step pause continuously. i may have to rma the card. i've already done so once.
When did this problem start? Did you change anything around the same time? What IDE/SATA drivers are you using? I ask because they can cause intermittent slow down problems.
What temp is your processor running at?
Marvelous said:
sounds more and more like a driver issue to me..
Could be, however, some 7600's have freezing problems. Why did you have to RMA it the first time?
cpu temp is in the low 40's.
i rma'd the card at evga's advice. they said it was a memory problem.
i was using the nvidia ide drivers. i uninstalled them to see if it made a difference. it did not.
i'm going to try the latest stock drivers and see if it helps.
Unfortunately, its sounds like your going to have to RMA it.
Somebody else might have some advice though.
Good luck!
Good luck!
i do agree with you as i have already tried every driver.
