Neo_Cloud_99
- Apr 18, 2001
I'll try to make this short. Computer used to be perfectly fine, not a single issue with software or hardware. Then just recently it started to hard lock in windows, or during the boot process. I did get an occassional blue screen error, but 90% its just a hard lock. What I usually have to do is just shut it down, and turn it back on, sometimes it works fine. The longest I can seem to get it to run now is about 24 hours before it crashes. Here's a temporary solution I've been coming up with, that for some reason, strangely enough, makes it work. What I do is unplug the power connectors from all the IDE devices, plug them back in, and bingo everything is ok again for awhile. Just tonight though it didnt even POST, I was finally able to get it to boot up normally after reseating the RAM. Prior to the POST issue I had just recently reseated EVERYTHING in the case, CPU, RAM, Power Connectors, IDE Cables, etc.
I am leaning towards Power Supply, RAM, or possibly MBD and/or CPU :\ ... its just hard for me to say for sure, so I was hoping someone might be able to help.
