This is my first attempt trying to setup a test Storage System.
My newly purchased hardware is:
Supermicro X8DT3-F motherboard
12 gig of memory
1 existing sata harddrive 80gig for boot drive
4 temporary existing sata harddirves 320gigs each for the data drives (to be replaced in the near future with five or more 2-TB sata drives)
O/S Windows Server 2008 R2
I am trying to test the above system with a small number of test data hard drives in IT (JBOD) mode. I am pretty sure that the motherboard has been jumpered in the default IT mode.
In the near future, when I receive five or more new 2TB hard drives, I will hopefully have learned how to set these up.
I have attached the 80gig boot drive on to one of the standard built in sata ports on the motherboard.
I have attached the four 320gig data drives on to one of the two SAS built in ports using a SAS to 4 sata drive breakout cable.
I have installed Windows 2008 R2 server O/S.
My problem is that the four data drives connected to the SAS controller do not show up in the Device Manager. If it is helpful info, a "LSI Embedded MegaRAID" driver does show up under Device Manger -> Storage controllers.
How does one go about setting up a string of data hard drives as JBOD's when connected to the SAS controller?
12 gig of memory
