- Jul 5, 2007
Running a Silverstone DA850 that has served me well through numerous rebuilds. Over the past several months, two of my four hard drives would sometimes disappear. It happened randomly. First I blamed it on the Lian-Li hard-drive hot-swap cage that had been around for very many rebuilds, and got a new one. That didn't help. Then I blamed it on the motherboard (a Maximus IV Extreme), the SATA controller must be failing.
New motherboard, all was well. Now it's happening again. Same drives, same problem. When it happened again today I could hear a drive like it was struggling to spin up. Whirrrrclick. Whirrrrrclick. This has gotten me wonder if the power supply is insufficient. I'd think that 850W should be fine, but maybe this power supply is on its way out?
Specs are as in the sig. The three HDDs are a 500GB Velociraptor, a 750GB Caviar Black, and a 2TB Caviar Green. The liquid cooling is a Swiftech MCP35X. Four radiator fans (BitFenix Spectre) and two case fans (one more Spectre and one Scythe "Slip Stream").
Any suggestions? Can anyone confirm or deny 850W is enough for my build?
