I am having a hell of a time getting Vista installed on a brand new WD 500GB SATA hard drive. When I almost get Windows loaded I will hear the hard drive spin down, then back up. Each time it does this the mouse freezes on screen.
I believe this problem is related to my previous problem. I had two other hard drives with Vista installed on them and they would have the HDD activity light go on solid then Windows would freeze requiring a restart.
I thought it was the hard drives starting to die so I bought a new one (I wanted one anyway) but it turns out I am having problems with it too. I am starting to really believe that the PSU is dying instead. It is an Enermax 350W PSU that is over 5 years old but it has been running fine in my Athlon XP system since I bought it.
I will replace it with a cheap PSU i have sitting around that I use for bench testing and see if it cures my problem. I know that the PSU isn't being overloaded as I have removed quite a few devices from the system that were originally powered by this Enermax PSU.
I am curious though, could it be something else failing? The motherboard perhaps? I'm not sure what else it could be.
