I have a WD250 and a WD120 for my 2 SATA HDDs. Recently I had bought an SATA power splitter that takes a regular 4 pin power and transforms it to 2 SATA powers. After doing a lot of wire management to hide my old 4 pin power plugs, I plugged my SATA splitter up to my 2 drives, closed everything up and booted, only to find the following error on startup: Error loading OS
So I change my boot settings to my DVD, pop in my windows disk for repair, and after loading all its bloatware, windows says it cant FIND any HDDs.
So, after messing with mobo settings (Asus P4G8X deluxe) I keep getting the same error, either it says Error Loading OS, or Windows Could not start because the following file is missing or corrupt: windows/system 32/config/system
And then it says I can attempt to repair this by using the windows disk
So, I UNDID all my wiring, plugged in the original 4pin powers, and holy crap, its the SAME THING. I'm fairly certain I didnt fry BOTH HDDs at the same time, I can hear them spin up as they turn on, and the cooling fans mounted on them spin, So THAT must be getting power.
I suppose I have 3 questions then:
1) DID I fry BOTH my HDDs at once? If it was just a corrupted MBR then Why wont windows detect any HDDs
2) Is there a wrong way to plug in an SATA cable, as in, can they be put in backwards or something
3) Do you guys have any advice on what to do? I'm at my wits end
Any help appreciated
****EDIT****
Ok, MORE problems, I put my SATA drivers on a floppy to load in windows setup to see if maybe THATS why it couldnt see it, but NOW it says it cant find a floppy drive.
It sees my DVD and CDrom drives just fine, why would a mobo not see my floppy or my HDDs?
****EDIT****
