hard drive wipe out
how do i wipe out my hard drive ive got a virus and the only way windows will open is in safe mode ive tried redoing windows it dont help plz help
i tried that dont work i need to wipe out hrad drive some how roxio corrupt my windows even when i try to install completly new windows will run set up then wont open in normal mode
when you installed did you do a clean install... ie did windows format your HD.... if you did do that (and you only have 1 drive) you have more problems then whatever roxio did....
True that.
i redone windows completly still leached on plz help i just want to wipe out the hard drive and start over
