Hi.
I recently purchased a Samsung SP1604N 160GB HDD. When i set it up etc, i had to use Ontracks Disk Manager to update my bios to support the size of the hard drive. After this the HDD worked fine.
Now, i used the 160GB to store all my data from my old hdd so i could format and re-install XP. I am now on a fresh install of XP.
The problem is, XP is not detecting the 160gb anymore. I have used Disk Manager but it seems the only way for that software to help me is to re-format, something i cannot do because i have alot of data on it.
There must be someway of getting around this, or at least recovering the data.
Any help will be very much appreciated, thank you.
Edit - I have updated my BIOS and installed SP2. Still no difference.
