Hard Drive Temps?
My Seagate 7200.7 (120gb/7200rpm/8mb) runs at 28C under heavy swapping. I have an intake fan (Panaflo 80mm Low) blowing over it.
EnderW said:
what are you using to measure it?
MBM5.
Settings > General > Scan for IDE drives with Temp Sensors > Restart MBM > Open Settings > Temperatures > Select an unused sensor > Select the drive under "Should Display board sensor > Apply (and configure the visual settings to your liking)
I think that's how I did it...
_Korruption_ said:
MBM5.
yeah I found it, thanks
my 74GB Raptor and my WD2500JD are both at 44 C, but this is in a SB75G2 Shuttle
