DougLite said:<30C: possible, great if you can get there, but not absolutely necessary
30-40C: pretty good, this should be your goal. Most drives will run happily for years in this temperature range.
40-50C: Not so good. Installing a modest fan (or moderate upgrade in fan size speed for one already present) in the area of the drive(s) should get you below 40.
50-60C: Bad. The reliability of drives operating in this temperature range is reduced significantly. Drives operating in this range require significant cooling upgrades, such as a new case, significantly larger and/or faster fans or other major actions to address cooling deficiencies.
>60C: Imminent failure.
protias said:speaking of temperatures, how do you exactly test this on your own machine?
CoW]8(0) said:I'm not sure why my Maxtor runs about 10C hotter than my WD drive. Both are 160GB 7200RPM with 8MB cache and mounted in the same place.
The Maxtor is a SATA while the WD is a PATA.
Is there any difference in using the Maxtor's molex connector rather than it's SATA power connector?
Maxtor drives always run hotter, as they draw more power. Simple science from there. You're observation that the drives are same is correct, and the extra power drawn by a Maxtor drive has to go somewhere, and it's dissipated as heat.CoW]8(0) said:I'm not sure why my Maxtor runs about 10C hotter than my WD drive. Both are 160GB 7200RPM with 8MB cache and mounted in the same place.
it depends what efficiency you are talking about.CoW]8(0) said:So basically Maxtor drives are less efficient than drives by Western Digital etc?
CoW]8(0) said:Well the ratio of the work performed over the energy consumed is lower than my WD drive. In fact, according to HDTach my WD PATA drive outperforms my Maxtor SATA drive.
CoW]8(0) said:Interesting.
Also, out of curiosity is HDTach benchmark affected when the hard drive has data or partitions on it? Because when I compared the performance, my WD drive had 2 partitions and a bit of data while the Maxtor drive was just formatted.
