Need some advice on handle a HD which I assume is on it's last legs.
My brother has a 6 year-old Dell which has pretty much run without any problems since he got it. Today though, after getting back from work and turning on the comp he yelled for me to come to his room. When I got there I could hear right away that something was wrong. The computer was making a rather loud "clacking" noise; it was so loud I thought at first it was the floppy drive on the fritz. Despite the noise, the computer booted up normally. When he logged into his account, I right-clicked the floppy drive to disable it, then realized that the "reading" noise it made without a disk in it overlapped the "clacking" noise. Obviously this meant it wasn't the floppy drive that was screwy. I've never had a HD go bad on me so I don't know what it sounds like, but common sense told me, if your comp is making a noise you've never heard before, turn the damn thing off. So I did, or rather I tried to.
An un-related problem with the comp is that occasionally it'll go through fits where it won't shutdown, only reboot. I know it's probably a driver issue but I keep procrastinating to diagnose it, knowing that it'll eventually go away (always does). Well, it so happened that the computer was going through one of these "fits" at this time so when I tried to shut it down, it just rebooted. When it did, the clacking noise quieted down a few notches; I could hear it only if I put ear close the computer. I tried to shutdown again, this time from the user account screen (instead of inside an account); thankfully, it didn't put up a fight.
So, right now I'm trying to figure out how to proceed from here. His computer has two HD's, both filled to near-capacity. The HD with the OS on it (C
was bought a year or two ago and other drive, which originally came with the comp (G
, contains only mp3's.
Obviously, the first thing I need to do is find out which drive is going bad. Should I disconnect the power and IDE cable from the G: drive, then start the comp up and see if the noise starts up again? Or is it playing with fire to even the start the comp again?
Much thanks in advance.
