Hard drive slowing down?
do0odo0o
okay this is what i found out.
under Primary IDE Channel -
Transfer Mode: DMA if available
Current TRansfer Mode: PIO Mode
under secondary IDE Channel -
Current Transfer Mode: Multi-Word DMA Mode 2
and i checked and my hard drive is using its own IDE cable. not sharing with anything else.
stuipid guessing question: does this mean i have to change my hard drive to slave or something and it'll work?
well if the Primary Channel has the HDD thats slow, there is your answer, there is a massive difference in speed between DMA and PIO
PIO modes
DMA modes
what is attached to which channel?
(give channel & Device(s) and if its\they are master or slave)
device Model too (make, model number)
you may need to uninstall the drivers for the IDE ATA\ATAPI controllers
or update them, you might need to alter your physical config
ect
need some more info
when i start my computer up this is what it says :
Primary Master: IDE hard disk
Primary Slave: not detected
Secondary master: my burner
Secondary Slave: dvd rom
(then just below that information it says this)
Primary Master: TX60A6AA IBM-DTLA-307045
Ultra DMA Mode-5, S.M.A.R.T. capable but disabled.
Under my Primary IDE channel properties: Device 0 is my hard drive
device 1 is nothing.
Under Secondary IDE Channel Properties: Device 0 is my burner and Device 1 is my DVD rom.
did i miss anything???
OK what motherboard do you have I'll check for new drivers
in the meantime, back in device manager
uninstall the Primary, Secondary and busmaster controllers
and reboot, they will be reloaded, see if that allows you to run in DMA
Im going to sleep right now, but will check this thread (if you reply) and find the latest chipset (bus mastering) drivers for you
If you dont know your mobo\chipset run
AIDA32 (Freeware) and or Belarc Advisor (also Freeware)
and download the IBM\Hitachi Drive Fitness Test or burn the Ultimate Boot CD which has that as well and test the drive itself
here my mother board the chipset
KT3 Ultra Series. by MSI
Via KT333 chipset based
and thanks so much for doing all this work for me.
maaaaaaaaaaaaaan
i did a quck install of those drivers.... and i still can't get out of PIO =(
tell me about your cables
how many wires? 40 or 80
where did you get them?
how long are they?
do you have any other 80 wire cables?
alright.
its an 80 wire cable
i think it came with my motherboard which i got like 1 1/2 years or something.
its about two feet long.
i tried my friends and it didn't fix anything.
just did this:
went into bios just to check things out, went that that normal bio's thing. anyways. my hard drive wasn't on 32 bit transfer mode. that was turned off. so i turned it on. but it didn't fix anything. ...... soooooooo just lettin ya know
i just ran that fitness test..
it told me i had one or more bad sectors. and that i could either totally erase my drive to fix it. (which i didn't want to do).
or i could use the sector repair thing. it said that caused data loss and i didnt' want to do that either.
could that be whats causing this you think?
or is that just something totally different?
well sectors do go bad
and enough of them could seriously interfer with the filesystem
might account for the PIO? not sure
do you have backup of this data yet?
Id make that your first priority
then run chkdsk /r
what is chkdsk /r ????
i know how to run it, but what does it do?
and the ide is 18inches
figured, thats the "standard" longest length "allowed"
chkdsk
"Creates and displays a status report for a disk based on the file system. Chkdsk also lists and corrects errors on the disk. Used without parameters, chkdsk displays the status of the disk in the current drive"
the /f parameter is
"Fixes errors on the disk. The disk must be locked. If chkdsk cannot lock the drive, a message appears that asks you if you want to check the drive the next time you restart the computer. "
its best to run it at startup
"Using chkdsk with open files
If you specify the /f command-line option, chkdsk sends an error message if there are open files on the disk. If you do not specify the /f command-line option and open files exist, chkdsk might report lost allocation units on the disk. This could happen if open files have not yet been recorded in the file allocation table. If chkdsk reports the loss of a large number of allocation units, consider repairing the disk.
Finding physical disk errors
Use the /r command-line option to find physical disk errors in the file system. For information about recovering physically damaged files with recover, see Related Topics"
before you run chkdsk, Id try to backup anything you havent already got elsewhere ;)
to ice czar:
hey man, thanks for all the help. but i think i found out what was probably the problem.
on the back of the hard drive where the ide plugs in. one of the little needle pins is pushed down. into the HD. so it can't connect to the IDE. i think thats what the problem was.. maybe. hah
but anwyays, i just bought a new 120 gig maxtor, because i thought it was time to get a new hard drive anyways. (i was also having some problems with the HD getting power. some of the medal things wern't touching each other.. i'd have to like push them back on each other every once and a while.
anyways i got a 120 gig from best buy for 79.99 after two 30 dollar rebates. so i'm happy.
and again thanks for all the help you gave me.
