hard drive recommendation
kiz
i need a hard drive no bigger than 60 gb that will be used for storing all my music,movies, etc.
What is the cheapest but best quality drive that you guys would recommend?
I'd get Maxtor, WD, or Seagate...they're all basically the same if you only want to use the drive for storage.
Check deal sites like www.bensbargains.net for cheap deals on hard drives.
A couple more resources to check out:
The performance database and reliability survey at www.storagereview.com will tell you just about everything you wanted to know about whatever drives you're thinking of purchasing (the reliability survey will probably be more useful to you in this case).
Another thing to think about is that warranty. If prices are similar between brands, get whichever one has the longest warranty. :)
