hard drive questions?
vertigomhs
i just got a new wd6401aals (wd black) and i was wondering is formatting in windows was fine and if so, do i just choose all the default values such as default cluster size and etc?
should i be worried about cluster size?
EDIT: forgot to mention, this drive will become my primary drive once i test it out and make sure it passes some tests, vista will be installed on it (if it matters).
Defaults are fine, but the Vista installer can also partition and format it.
