Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
My apologies for not being very clear. So, for example, can I take the IDE that is what holds the OS and keep that primary while making the SATA a slave? If so, is there any type of jumper configuration that needs to be done?
Sure, just make sure the disks are in the proper "boot from" order and all will be well. It's suggested that you leave out all but the disk you're installing Windows to, though, so you don't inadvertently nuke the wrong disk.
