Apr 28, 2006 #1 S stev3-o n00b Joined Dec 17, 2005 Messages 19 I have a simple question. Will a sata1 hd be raidable with another hd that's sata2?
Apr 29, 2006 #2 U unhappy_mage [H]ard|DCer of the Month - October 2005 Joined Jun 29, 2004 Messages 11,455 Yes. But it's best to use drives of the same type (speed, revision, firmware even) in a raid array. Performance problems can happen, even though it's not very likely.
Apr 30, 2006 #3 H hity645 [H]F Junkie 2FA Joined May 11, 2005 Messages 9,018 I wouldn't see why there should be a problem. The jumper effectily tells the drive to run in either sata 1 or 2.
