Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
You could use a utility to blow away your D: drive, and then expand your C: drive to the full size of the disk. Partition magic will do this for you, as will many other utilities. You will loose all the data on the D: drive though. If you go this route make sure you backup any important data off your laptop as there is always a chance of losing everything.
