Hopefully I'm in the right place.
Last Friday I bought a new, 1tb internal Hard Drive (Seagate). I hooked it up, fired out XP professional 32bit and installed the OS. I created a new partition with the default size that they gave me (which from my experience is the maximum HD space, but I could be wrong). After finishing the install and putting some of my basic software on it, everything seemed to work fine. However, after a few days of transferring about 30gigs of files onto it I noticed something depressing: in Properties under My Computer, the total drive space read as something around 125gigs. I'm pretty certain that I didn't do anything wrong with the partition, unless the default partition size is around 1/7th of the available space for some reason.
I mentioned it to a friend and he told me something about a partition cap with NTFS file systems that are default with Service Pack One? He said he'd heard that sometimes they only display a small, block portion of the total memory, and that there is a simple procedure that will fix the problem and display the rest of the space.
If anyone is familiar with this problem, knows said procedure, or can give me another solution, I'd much appreciate it. It will really suck if I need to re create the partition.
