Hard Drive Overheat Symptoms?
200mg
Basically, if i play a game for a long time, or just leave the computer running for a long time downloading stuff, when i try to start a game my computer loses connection to the monitor, then regains connection and shows me a screen not too much unlike snow/static on a tv set, but with color. I have oc'd video cards in the past until they lock up, and thats what this screen looks like if anyone is familiar with that.....Then it auto reboots after a couple of seconds. My vid card temps and cpu temps are well within spec.
What I have noticed is the HDD is getting hotter than spec after not being on for long at all. The capacity is 55 degrees celsius and right after boot it's at 56 degrees. I'm going to get a HDD cooler for it, but I was wondering if this sounds like that could be the issue. Could an overheated HDD cause the symptoms I described above?
TIA for any replies.
