Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Theres only 2 differant threads used in a case, theres the 6-32 and the M3 I think it is. you can get them at most hardware stores. M3 is used on CD/DVD drives and some motherboard standoffs, 6-32 is used about everywhere else and also some MB standoffs. Fans on the other hand use something tottally differant, I believe there #8 screws but they are special fans screws but i seen people use sheet metal screws before.
