HardDrugsUser
- Nov 12, 2007
Hi,
Yesterday I was examining the HD mounting mechanism in my new Lian-Li v1010
The case uses rubber rings to mount the HD and by this preventing vibration.
This got me thinking about a static charge and after a short search in Google for "harddisk grounding" a lot of stuff came up.
Appears to be that I will have to attach a separate wire to the body of my Hard Disks and the case to prevent static electricity from building up
Any thoughts?
A grounding tab provides a positive ground connection between the drive and the system's chassis. In most systems, the hard disk drive is mounted directly to the chassis using screws so the ground wire is unnecessary. On some systems, the drives are installed on plastic or fiberglass rails, which do not provide proper grounding. These systems must provide a grounding wire plugged into the drive at this grounding tab. Failure to ground the drive may result in improper operation, intermittent failure, or general read and write errors.
Any thoughts?
