hard drive jumper question
133
heres what i have...
1x20gb drive
2x10gb drive
1xcdrom
they are all IDE
i wanna set the 20gb as my master hard drive
question: what cable do i put the master drive on and what do i set the jumpers to on the optical?
Set hard drive to master/slave or both to cable select (this will go on your Primary IDE controller)
Use another ribbon set it cable select (This will go to your secondary IDE controller) and the other drive as cable select.
Cable select will just select whether it's master/slave depending on which position the drive is connected to. If this is too difficult, just set each drive to master or slave.
Each IDE controller can handle two devices Max.
