Hard drive in the freezer.
AngryJim
So I had three hard drives in my computer, a 320gig drive with my operating system, a 500gig drive for storage, and a 1 terabyte drive for storage. About a week ago my computer started acting extremely weird, and during one startup it halted and gave me a cryptic message that a drive was failing (but not which one). The next day I turned on the computer to find that the 500gig drive was not available, and I assumed that was the drive that had failed, so I popped it in the freezer to try and save some data.
Several days later, my computer was still acting weird, and I got the same message. It turns out that the drive that was failing was the one with my operating system on it. I'm guessing that's why the 500gig drive went missing, because the OS was being corrupted.
Anyway, long story short, I have a perfectly good 500gig drive in the freezer with some data I'd like back. Are there any precautions I should take in letting it warm back up to room temperature, or have I completely hosed it by prematurely sticking it in the freezer unnecessarily?
I would just let it return to room temperature but you could probably use it right away with no issue whatsoever. I would just play it safe if its data you REALLY care about.
Take it out of freezer and don't use it for a few days. The only problem is if its ice cold condensation will form, so u then gotta let it dry. Unless u put it in a ziplock bag or something when u put it in the freezer, then just let it warm up in the bag and condensation will form on the bag instead.
No problem then, just take it out and leave it in the bags until it warms up. Wait an hour or whatever till drive is room temp then take it out of the bags and use it, no problem.
The idea with the freezer trick isn't to actually freeze the drive, you only leave it in there long enough to cool the electrical components down. Generally it only works on drive with failing controllers and won't help with drives that have anything failing hardware wise.
But yes, pull it out and let it sit over night and should be no problem next day.
I posted this same info about 2 minutes ago in another thread
in this subforum, so you might have seen it already.
When I used the freezer trick:
40 minutes freeze
10 minutes copy data off
40 minutes freeze
warmups would make the files not visible...
it is inside several ziplock bags, still inside the freezer.
Nice precautionary measures! as a side note for the data/OS corruption, try putting your Ram stick(s) in different slots. I've had 'HD Failures' caused by bad RAM / RAM slots, causing bad data to goto a good HD.
And potentially try switching SATA slots, if not the cable itself.
Good luck ICEMAn ! :D
