Hi,there ppl can some please what i have to do to hook up my IDE hard drive to my computer that has SATA hard drive,i tryed to hook it up as a slave,along with my cd drive ,which put as master,and when i turn it on it woul'nt boot up thanx.
You mean on the same IDE cable as the cd-rom? First thing to check is that the jumpers are set right on the hard drive and the cdrom. Easiest way to go is putting both devices as cable select.
