Robizzle01
- Sep 30, 2005
I have a dell laptop and a diy desktop that I use as a fileserver and apache test server. Over the last year I have become more and more interested in linux and I started using it exclusivly last september. First only on my laptop which I setup to duel boot windows xp. A few months ago my laptop started falling apart, dvd drive clicking, hard drive had bad sectors, graphics card died, and keyboard failure. I shipped it in to dell twice during the school year for repairs on those items. Before shipping I always ran shread on my hard drive from my gentoo boot disk to hide the fact that I used linux and that this _may_ void my warrenty. I'm not sure if it really does or not but the cutomer support from dell that I talked to (who didn't seem to know much of anything) told me that using linux would void my warrenty and replacement plan. I never did end up getting the bad sectors on that hard drive fixed, i just have them marked as bad sectors and linux stays away from them ... i guess.
However, I would like to replace the drive since it is under warrenty and it is defective. I know that it wasn't linux's fault but that doesn't do me any good in arguing with them. I tried installing windows on the entire drive and overwritting linux compleatly -- it installed and worked fine. I then ran check disk or whatever its called and it didn't report anything (maybe it just fixed it without telling me?) Since windows isn't reporting errors, I wasn't able to send in the hard drive. I reinstalled linux and of course all the check disk programs spotted bad sectors using the read/write nondestructive test (fsck.ext3 /dev/hda -cc). What should I do to get this defective drive replaced if windows wont report the errors even though they are there?
My next problem is with my desktop. I ordered two 300gb Maxtor Maxline III drives from newegg 6 months or so ago. I liked the fact that they had 5 year warrenties and were supposed to be some of the least failing from what I gathered. It took me a few months but eventually I filled up both drives halfway, at that point I noticed bad sectors on the second one
They were in an XFS raid so I lost everything -- couldn't find any detailed guides about data recovery for that kind of a situation online. I attempted to just mark the bad sectors in linux like I had for my laptop since I didn't want to bother with customer support and all the headaches if I could help it. That ended up not working and I reinstalled and started over from scratch again. Just yesterday my drive got full enough again that I lost the drive again -- this time i did two seperate ext3 partitions so as to maximize my chances of recovery. I got all my files off of it but now I want to get the drive replaced under warrenty.
Maxtor's website makes this difficult... To make a return they require the user to enter a code generated by thier diagnostics program. This program seems to be only downloadable for windows ... great. After screwing around trying to get it working, I ended up finding a bootdisk iso of this utility. Burned it, booted and the program froze at the "detecting hardware (this should take 1 minute)" part. I tried unplugging unneeded hardware and such but no luck. Now I have no way to get a diagnostics code so that I can send the drive in for replacement. What should I do? If I fill out forms on maxtor's site should I mark linux or windows as the operating system?
I write this thread mainly to ask you guys what I should do and also about linux and warrenties. Does linux void nearly all hardware warrenties? dell? maxtor? Do any of you have similar experiences/stories?
