hard drive error rate/not ready
I have a brand new HGST SAS drive that is not coming online after running a few verify cycles via the HBA and has the occasional chirp. I get over 250 hard errors in a hour. Any thoughts?
kstat -n sd2,err
module: sderr instance: 2
name: sd2,err class: device_error
crtime 65.751936841
Device Not Ready 57
Hard Errors 115
Illegal Request 0
Media Error 50
No Device 8
Predictive Failure Analysis 0
Product HUS726040AL4210 9
Recoverable 0
Revision A519
Serial No N8G166SK
Size 4000787030016
snaptime 434.097213856
Soft Errors 0
Transport Errors 4
Vendor HGST
I'm of the opinion that if you're seeing hard errors this early into the lifetime of the drive, RMA it and swap it out for a replacement.
Try another Power/SAS Cable or slot, and if no change then RMA the drive it's toast.
I got 3 more HGST hard drives in. All drives sound good. In the SAS BHA menu, I did 2 verify cycles and a format on the first drive, just like the previous failed drive. They all passed. I then attempted to do one more verify cycle of the the format, but it failed. What could be causing the issue?
The drives are connected via:
Supermicro X8DT3-F MB
LSI 9207 SAS HBA, on PCI port 5
Supermicro BPN-SAS-846EL2 backplane.
Edit: It appears that somehow formatting the drives is killing them as I am now 3 for 3.
