AtomicFire
- Dec 7, 2001
Heres what i'm planning to do:
Theres an old PII-300 Compaq Proliant serveri my basement being the router\file server.
What I plan on doing is putting in 4 Firewire 400 cards, and getting 8 hard disks (2 per card).
Then i'll get 8 external firewire enclosures and put 120gb hard disks in each, yielding 960 gb of storage.They will be in a RAID 5 array, software, under linux. Speed isn't important, reliability is. I want to be able to hot-swap and rebuild in case any hard disk takes a shit and goes down without rebooting the server or losing data. Backup images are going on this server. I figured this would be cheaper than going hot-SCSI\hot-IDE or SATA all the way.
I've had 3 hard disks die on me in external enclosures because of their crappy cooling. Can anyone recommend a good external enclosure from experience that has the following qualities?
1. Good cooling capacity. I like 3.5inch enclosures, but if need be to cool better, 5.25 is fine.
2. Stackable OR can be placed vertically in a stable position.
This is stable
This is not
3. Activity lights on the front where it is easily viewable.
4. USB or IDE is fine, i'll be going with whichever has better cases.
Thanks for the help
This is stable
This is not
Thanks for the help
