My Windows has gone completely unbootable twice in the last two weeks. I had to get into the recovery console and do chkdsk. Both times it found 3+ errors and fixed them. Both times after chkdsk it would boot into windows fine. Also, at least one of my hard drives spins up followed by a quick spin down at bootup, locking windows up at the loading screen until I reboot, after which it has worked after 1 reboot multiple times.
Dieing hard disk?
(One in question is the 80gb WD)
A7N8X Deluxe() XP2400+ @ 2.379 [have tried it at stock, temps are fine] () ATi 9800 () 512mb XMS PC3500 Platinum () 2 WD 120gb SE in RAID0 () WD 80gb [boot drive] () 50x CD drive () 52 Lite-on CDRW () Cooler Master ATC-111C-SX1 () Thermalright SLK-800 () Thermaltake Smart Fan II () WINXP Pro
Dieing hard disk?
