No earlier than last night, I was simply surfing and listening to some music as I normally do on my rig when I decided to shut down for a few hours. Upon my return, I noticed that the windows xp boot took literally 10 times longer than it normally does (about 30 some odd rotations of that blue bar). A few restarts later and the problem seemed to go away. Fast forward about 1 hour later, I noticed simple things like firefox would take minutes to load and after another restart, the boot problems returned. Everything takes exponentially longer to load.
Now, I ask if this is a hard drive problem because my second drive (my 160 gb WD storage drive on the EXACT same ide channel) loads things like a champ and after additional speed tests, I know the second drive is running top notch. On the other hand, the primary 60 gb drive came back with these results :
As you can see, I'm being beaten by a usb drive
. Again, my second drive on the ecact same ide chan performs perfectly. This does not. Any help would be appreciated, thank you.
