Hard Drive based on DDR/SDRAM (not typical SSD)?
I am looking for a nifty, cost effective solution to extend the capacity of standard x86 servers but cannot seem to find what I want. Maybe some of you fine people here know of the existence of such thing.
What I want is a Hard Dirve that is much like a Solid State Disk but not quite. I would like a way to turn DDR/SDRAM into ultra fast and volatile storage. The idea is to use this as a swap file storage.
Imagine, a swap file almost as fast as RAM! I know that all data is lost this way but who cares about stale swap garbage after a shutdown/restart/power failure?
Ideally, this system would provide a standard IDE/SCSI interface and comprise of standard DDR/SDRAM sockets, so one plugs in as much RAM as he wants strorage.
Ideas and references welcome.
Yep - iRAM has been out for quite a while now although it is only SATA which most branded (IBM, Dell, etc) servers more than a couple of years old lack. There are a couple of others out as well but they are extremely expensive and then one more newer one which I cannot remember the link to but they have had a page up saying it coming for what seems like a year or more.
You can always just get a SATA->IDE adapter if you only have IDE connections.
The iRam will take up many PCI slots to get any decent capacity. You'd want to completely max out the motherboard's capacity for memory before you even thought about dealing with the iRam - onboard memory is several GB/sec, iRam is only 150 MB/s. And it only holds 4gb.
What exactly do you want this for?
