Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm trying to decided on one of these HD and can't seem to make up my mind.
Can someone advice me on which is the better buy?
Only thing that I see that is diffrent is the Buffer size, Is that important?
Seagate 80GB [ Link ]
Western Digital 80GB [ Link ]
Of course, one could argue that the longer warranty on the Seagate makes it a better buy. I'm not saying that it is, I'm just saying it's something to consider.
Seagate makes good drives. If I were you, I'd go for a Seagate with a larger buffer than the one you've selected, even if it does cost a little more.
Your comparing drives from the two best manufacturer's, IMHO, so you can't lose either way in terms of reliability. But, as others have said, if you have to choose between those two, the WD will easily be the faster of the two. There's no comparison in performance. That part makes me throw my vote to the WD drive.
