JacobC1983
- Sep 4, 2006
I put a new power supply in my rig and I have a problem
My hard drives are located in such a way that they need a 90 degree adapter for the power connector to meet the hard drive and the side of the case to shut completely
I have the correct SATA cables, I bought them specifically with one end have 90 degree angles... but my power supply doesn't have the same angles.. and was wondering if there was a connector to put onto the end of the power cable to make it a 90 degree angle so my new power supply will work and I can close the side of my case
anybody know where I can buy this sort of connector?
thank you for your help!
